Hi,
I just bought a 1985 9k Turbo and have a bit of problems with the antenna.
A previous owner has "modified" the wiring harness behind the radio with a pair of pliers and I can't really figure out which wire to connect to the 'Antenna remote' plug on my headunit.
Alternatively, which of the wires on the antenna is the "trigger"? I have red, green and black going up to what looks like a relay - and white, brown and yellow from that down to the antenna itself.
I have a couple of amps I plan to throw in the trunk, and it doesn't really matter if I have to pull a new wire from the headunit to the antenna - I just want to be able to listen to the radio
Discussion Starter · #2 ·
Okay, went out and pulled out the radio again.
I managed to find couple of loose wires (presumably cut with the same pliers), a blue/red and a red/blue. Are any of these supposed to make the antenna go up/down?
Anyway, they didn't
Any ideas on what to try?
Can I supply 12v to one of the wires going to the relay (red/green/black) and make it work that way around?
Thanks in advance,
