Wasaabi, I'd recommend that you drain that stuff out. The synthetic that Saab uses is a special formulation that has an additive that increases ASTM bearing strength. Mobil 1 and regular synthetics are designed to "roll" and the Saab oil is designed to "slide". "Rolling" oils do not support the forces found in the 9000's crown gear, which has sliding friction engagement and very high bearing stresses at the interface, and don't have the bearing strength of fossil oils. All 9000's came with fossil oils, until '98 which was the 1st year, IIRC, that the transaxles came from the factory with their own synthetic blend. It's anecdotal, but I've heard that many from Saab Engine Development considered Quaker State 10W-40 one of the best oils to use in a 9000 transaxle.
