I got a strange noise when moving the gear lever to the right side, second gear, return gear, 5th gear. It sound like there is a kind of a spring which makes "ping":confused:
it sounds like there would be penny hitting shortly metal.:eek:
Has anyone an idea?
Regartds Bill
Discussion Starter #2
Does anybody knows where to see how to dismantle the gear lever in order to check the noise?
Discussion Starter #5
A very funny and strange story: First of all the key blockedk in August 2019. Could not get ignition because the gear lever did not move at all. Afrter some trials it worked again until last week. Wanted to start the car the gear lever did not move. End of trials. Repair shop. The reason for the blocked ignition switch was screw nbr. 19 which holds part nbr. 16..and the screw was lost and never found.
This also made the noise when moving the gear lever. Problem was very annoying and expensive.
