Status
Not open for further replies.
I started with headlights that would not switch reliably to full beam reliably. Thanks to threads on Saabscene, I checked the full beam switch first, which seemed fine. So, just fitted a replacement "A+B" relay from a breakers.
Now switching to main beam and back is better, but not perfect. However, if the headlights lights are off, using the stalk does not flash the lights . Not that I am a regular flasher, but I like things to work.
Is there another relay ? Any other suggestions ?
Where can I find a circuit diagram for a 98 Anniversary ?
Have you tried putting the old relay back and seeing if that flashes?
If it will switch from dipped to MB and back then the switch is working so with the lights off the stalk will be doijng it's stuff.
I would check the new relay first and the conacts in the relay box.
Status
