Can anyone help me - I am after a schematic for the fuel system on the above car.
The 12V wire to the fuel tank fuel pump is shorted to ground. Tracing the wire back from the 20A fuse via the pump relay, and the loom looks to go to the engine compartment before tracing in the loom on the N/S back to the pump. There is the problem, where does the wire go to within the engine compartment? I had assumed that the 12V would feed via the 20A fuse then through the relay and directly to the fuel pump - but it doesn't!.
Any help would be appreciated.
Peter
Peter
