Question.....
will a 3 bar FPR (off a B235R) fit straight on to a B202 fuel rail?
looking at getting a 2nd hand FPR off a 9-5 aero and wondering what performance increase i may get from it (of course i am waiting for the funding for a fuel chip... would that be a better investment now and a new FPR later???)
looking for more torque and
out of my '87 9000T
An upgraded FPR does not make power. It adds margin of safety.
Basically the FPR will only give you added performance if you're running too-lean ... in which case you will run richer with the 3.0 bar FPR, and shouldn't detonate.
But ... a better investment is a fuel chip, and a set of high flow injectors.
Better investment still (though far far more expensive) might be a stand alone engine management. But this is a topic for people seeking 300+ hp.
The stock B202 injectors I believe are good to around 200 bhp. Until you cross that line, an upgraded FPR could make your engine run too rich, and harm performance.
It's just a bandaid fix, and there are better solutions, and better ways to make power. Though running rich is better than blowing your engine to bits (detonation at 200+ hp).
Dubbya~
thats basically what i was looking for.
I am getting detonation at 15psi at the moment, and i am running retarded ignition timing (around 14 deg advance, instead of the 16 that is standard). i am hoping that a higher FPR would give less chance of knock at the higher boost levels, and also allow me to advance the timing up a bit so as to get the power back to where it is supposed to be.
i know that i can hold 15 psi to the redline if i have the timing retarded to 10 degs, but the car feels sluggish at that timing.
btw.. anyone know what the stock peak boost is for this car? i remember getting 12 PSI once (before i tweaked the apc) and was pretty happy..
Another question..
my car has the Bosche Jetronic LH 2.2 with catalyst.... will a fuel chip still work with this, as the O2 sensor will adjust the mixture back if it is richer????
does the fuel chip do more than just giving more fuel?
Originally posted by Grentarc:
[qb]Another question..
does the fuel chip do more than just giving more fuel?    [/qb][/b]
The fuel chip allows you tu use much larger injectors.
Also, your O2 sensor is not used by your ECU when you're at full throttle. It only controlls a/f ratio when you're cruising.
With a catalyst you need to be especially carefull about running too rich. Too much unburnt fuel can damage it, though it's unusual for this to occur.
Dubbya~
HOw about a Rising rate FPR. Anyone have experiances running one? I have a good deal on a cartech FMU presenting itself to me. Anybody set one up on a b235R?
