Scaero has just fitted my old T2 actuator to his Aero (also a TD04), although I think he might have made up an adaptor plate.
Forge also do T3 and other pattern adjustable actuators.
Posted by BillJ:
  Thought you had the TD04 (Viggen) turbo in yours, Stanley?  [/b]
I have a modified GT25 fitted at this moment in time. But I'll contact Forge to make sure.
I already concluded that fitting a Forge recirculating DV was a good idea in order to protect my turbo against back pressure build up from my 10PSI WGA and MBC
. But fine tuning the WGA and hopefully being able to dump the MBC afterwards is looking more and more like another of my crazy experiments
Thanks for raising this point BillJ .
Originally posted by Mark E:
[qb]Scaero has just fitted my old T2 actuator to his Aero (also a TD04), although I think he might have made up an adaptor plate.
Forge also do T3 and other pattern adjustable actuators. [/qb][/b]
Yes, I used a piece of 3mm mild steel and the TD04 actuator plate as a template.
Photoes to come soon.
