1 - 1 of 1 Posts
First some background information. Due to non use vehicle's battery was drained completely and had to recharge it. Prior to this the FOB/s woked fine.
Now either FOB will not centrally lock vehicle, however, if you hold down the "Open" button on ANY FOB each door KNOB thingy pops down and back up as you would expect it to do. Also I can lock the doors manually and the FOBs will OPEN them.
So, it's ONLY OPENING with the FOB/s that's the real problem. So what can it be ... the receiver maybe, if so, where is it located.
Finally, I have tried the disconnect the battery negative terminal bit and to no avail..
HELP
1 - 1 of 1 Posts
