Hi all
Just recently I have noticed that my idle speed has gotten higher and that it fluctuates. Usually it sorts it self out after about 5 to 10 miles, and if it had been a steady high speed then I would have assumed that it was just something to do with the automatic choke....but it is not constant. It wavers between 1100rpm and 1400rpm and every now and again as the revs drop it goes to far and stalls.
What should I check first? Plugs? Damp? Sensors?
Kev
Kevster, the usual culprits are vacuum leaks and the idle control valve, but if you type in "idling problems" in the search facility, you'll find all the info you need.
It's a common problem.
