Hi all
I seem to be working through various suspension components trying to sort out a vaguness around the centre line and a tendancy to weave on uneven surfaces and in high winds. The car is a 1993 aero and so far it has poly rear wishbone bushes and poly steering rack bushes. The rear wishbone bushes didn't seem to make any difference, but the rack bushes did seem to improve things soem what...but definitely still not what it should be. My options seem to be:
1. replace the front wishbone bushes
2. replace the ARB drop links (probalby for rubber..I'm just thinking that one may be softer than the other as one is newer than the other and so may pull to one side when riding bumps)
3. New shocks and springs (the rear driver side of the car does seem to sit lower than the other???)
4. Something else
I seem to be doing OK getting old rubber bushes out (transmission mount, engine torque arm mounts, rear wishbone, steering rack), mainly thanks to the excellent advice of this forum and also BillJ's great site, so I thought I'd do the front wishbone bushes next, and I was just wondering....
Do I have to cut the rubber off the old centre support of the old front wishbone mounts and push the new poly (superflex) mounts onto the old shaft? Or do they come with a new centre shaft?
Also, am I going to notice a big increase in cabin vibration/noise?
And finally (sorry, I am going on a bit)...am I barking up the wrong tree and really need to be looking at soemthing else as the likely cause?
Many, many thanks for an advice
Kev
4. Something else
Kev
