1 - 9 of 9 Posts
Ok - my front Koni's have finally arrived and I've just been looking at the pile of bits and pieces + the dubious instructions...
Anyway - I've got it sussed apart from the following -
When you insert the koni into the old strut, you are pulling it in using the allen bolt at the top and I assume it 'jams' into the open end of the strut (as the koni is wider at that end).
In the box is also a metal ring which looks as though it may be needed if the internal diameter of the old strut is 50mm (as opposed to 48mm where you don't need it) - instructions are at their worst here!. I assume this ring would sit into the open end of the strut (to make the hole smaller) and the koni would then pull into the ring??
So - have I got this correct + does anyone know whether the aero strut needs this ring at all?
I got mine done at a koni specialist. My advice would be to go to a garage that has fitted them before, and ask them to show you. I agree about the instructions though, they are terrible! I think they have tried to make it so they apply in all languages.
Mark
Originally posted by faero:
[qb]When you insert the koni into the old strut, you are pulling it in using the allen bolt at the top and I assume it 'jams' into the open end of the strut (as the koni is wider at that end).[/qb][/b]
Yes.
[qb]I assume this ring would sit into the open end of the strut (to make the hole smaller) and the koni would then pull into the ring??[/qb][/b]
Yes. I believe the Aero struts are wider than the non-Aero struts. I needed the rings for my Aero. It's easy to tell. If you need the rings, then the insert will drop all the way in and rattle around without the rings.
Thanks folks - as in most of these cases, all becomes clear(er) when you do the job - but it's nice to know the pitfalls upfront - much appreciated!
ylee - I assume you have non-aero struts? Or are you rattling a bit...
PS - I'll be in Blackness on Sunday so if you see a silver aero in the area, it will probably be me.
PS - I'll be in Blackness on Sunday so if you see a silver aero in the area, it will probably be me.  [/b]
no it wont ..it will be me
We always have our "Sunday Constitutional" in Blackness on a Sunday ...
small world !!
I had Aero struts and no they are not rattling
the konis fitted in no prob
the design has little bumps which "jam into " the old struts so stopping any possible rattling
the old "damper rod" was a bigger diameter but that is all...
1 - 9 of 9 Posts
