Has anyone noticed this rattle from using the DS 2500's? I took my front wheels off, yesterday, to investigate rattling which occurs over road bumps (railroad tracks, small potholes, etc). At first I thought it was coming from the rotor shields/backing plates, but upon closer examination I found that it's the pads, which seem to have excessive vertical play. I used a thin film of blue silicone gasket material to the backs of the pads, before I installed them, but the play seems to be in the up/down direction. Has anyone else noticed this with their pads? I bought the pads from Trent and I think that they did a slight grind but this was, I think, to the backs. I love the way the pads perform but the rattling is really annoying.
Robert,
the grind is to the top and bottom of the pads.
the ds2500 pads are about 2mm too tall, and their is a 1 mm raise on the top and bottom of each lug that runs for half it's length normally.
I ground mine myself, and did one pad (out of 2 sets) a little too much, but thankfully I don't have any rattles of clunks (it was an inner one though).
I have to say that I do love those DS2500's though, work when cold, and keep working when very hot. Squeel a little when used lightly at a crawling pace.
Thanks guys, I'll have to do some research on those clips that BillJ allegedly uses. Or, maybe put a dollop of blue silicone on the tops and bottoms of those lugs?
Originally posted by robert lavergne:
[qb]Or, maybe put a dollop of blue silicone on the tops and bottoms of those lugs? [/qb][/b]
errmm... you don't want to do that- it could end up messy. Brakes can reach temps above 300 deg C even without caning it round a track, which will make the silicon goo...
Bill's not around at the mo, but I'm sure he'll reply when he gets back.
Back now
As Andrew says, I had a clunk or "clack" on hard braking and on moving off after a hard stop. I also bought the standard size pads (DS3000) and filed them down myself. I went a bit too far because I suspected the DS2500s I was replacing might have been binding slightly (I'd filed those down myself too). There was noticeable vertical movement of the outboard pads.
I went to Halfords (local car parts chain) and bought a brake fitting kit with some clips that would act as shims on the top of the pad. Fitting these made no difference.
The clunk turned out to be a stripped bolt on the left-hand control arm bush. Luckily it was one of the two long bolts that go through the "butterfly" so I was able to replace the bracket in the floor that these screw into. Clunk is gone.
The amount of movement I saw on the pads would, I think, make some noise. I may remove the clips now to see whether any noise comes back.
