1 - 13 of 13 Posts
last night i started my car and switched on my headlights you know how it goes 1 click sidelights 2nd click mainbeam everything was fine until i swithed my fog/driving lights on my mainbeam then went off and only my sidelights and driving lights stayed on i assumed the filaments may have blown in both bulbs however when i drove the car tonight the mainbeam came on until that is i pressed the brake and once again back to the sidelights only what could this be? i initialy thought it was my bulbs or a fuse but now i just dont know and i dont want another arguement with a police officer explaining that my driving lights are exactly that and not front fogs any help please
On that year, it is most likely the relay as Leon suggests. There are no outwardly-visible signs. The only way to test it, as far as I know, is by fitting a know good relay.
A number of people have reported good results from opening the relay up and retouching all the soldered connections with a soldering iron.
It does come with time. Having had 9000s for the last 7 or 8 years, I've done a fair few jobs on them. I also watch the boards for people's problems, other people's answers and what eventually fixes the problems. Then I regurgitate the answers to make people think I'm clever
Which brings me to an important point - if this fixes it, let us know. If not, let us know that too. That way we all learn.
Discussion Starter · #9 ·
going to buy my relay today none of the dealers in the manchester area have any besides they were quoting me 44 quid + vat my local scrapyard have advised me that they have just received a 1992 9000 ready to strip just yesterday let you know how it goes thanks
I had a similar problem on my on my 9000 when I could never be sure if dipped beam came on or not - various suggestions from Saab including relays, column stalk and the control box which indicates bulb failure which I believe is a series of relays - about £160 from Saab.
I never did find the problem and Neil CS2.3T has the car now and I think cured it so he may be able to help. I didn't think main/dipped relays were as expensive as that.
Mike
My Aero used to not switch from dipped to main and vise versa.
I finally traced that to the connector on the back if the stalk mechanism.
A bit of juggling to remove and refit and all has been welll for 6 years now.
My mainbeam failed on my '94 model CS, and happened to be the orange plug-in module (under the bonnet along with the fuses) that detects the headlamps are working, or not.
Luckily I had just picked one up from a scrappies the previous week for virtually nothing to put in the toolbox, just in case! Sometimes you can be far too clever...but not often!
Nick.
Originally posted by LocoSaab:
[qb]I had a similar problem on my on my 9000 when I could never be sure if dipped beam came on or not - various suggestions from Saab including relays, column stalk and the control box which indicates bulb failure which I believe is a series of relays - about £160 from Saab.
Mike [/qb][/b]
Yes it's cured, it was the stalk switch that was at fault. So be prepared to do either/both the relay or stalk.
1 - 13 of 13 Posts
