Just had my pal round with his diagnostics tool, he has sent me a text
P1110 charge air bypass valve problems.
Is this the dump valve ? 2001 95 aero 230 man estate
Any help greatly appreciated. Cheers
Came home, looked under the bonnet and noticed the thin pipe from the dump valve that runs towards a valve/ sensor near the bulkhead had come off, in fact the whole pipe is slightly perished, cut couple of inches off and pushed back on, see if it's cured when I drive it to work on Monday. Elm light off at the moment, cheers for the link.
Premium Member
I would say that will be your issue, as a matter of cause I would replace vac hoses
I'm getting the same code because the the pipe keeps popping off. I glued mine back on today.
I reset the light earlier, but haven't driven yet. We'll see if it pops off again.
Cheers, I will replace all the hoses, brittle and some worn through rubbing etc, noticed the the connecting rod with a ball socket either end that holds the gear linkage rods away from the bell housing, the bottom ball attached to the gear rods has popped out allowing linkage to drop and rub on gearbox bell, another thing to replace as can't pop it back in?
