Slowly getting the carly back up and running. Just moved house, and the car hadnt been run for 2 months. Charged the battery - started 1st time no smoke, slight tappet noise (went quite quickly).....
But - the cooling fan doesnt work...connected the fan directly to the foglight switch (disconnected the lights of course) and it works fine. So, it is the case of a broken line under the radiator.
Querstion is which one. I looked at the 352 different wires.....and got a little bit sad. Can I tell without a multimeter??Is it possible to run a new wire?Where do I connect to?Obviously the fan....but at the other end???
Electrical bits and me don't get on.......
Help and advice appreciated as usual.
