Hi all - it's got cold all of a sudden, so the bike's gone back into the garage and the CSE has been taken out of it's sumemr wrapping.... But - the b*gger failed the MOT and I'm after a little encouragement ...
Fail points:
1) Front nearside balljoint - fixed: £8.50 replacement from GSF, 45 mins to fit
2) wiper blades not clearing - fixed: £8.00 pair from GSF
3) Hazards not working - fixed: 2 hours grovelling for the relay, soldering the terminals and refitting
4) Pilot bulbs not working - £0.70p GSF not yet fitted
5) Weld on turbo/downpipe manifold broken - fixed: 45 mins to undo the rusty nuts, 30 mins arsing around with the seized lambda sensor (I cut the wire and re-soldered it in the end), 30 mins splattering Mr.Mig over the joint to re-make it, 45 mins to re-fit and re-hang the system.
Now for the problems ...
6) 30% braking imbalance on both axles..
7) diffuse beam pattern on both headlights
8) main beam not latching on...
so - any help gratefully required oin these last three, the Tax expires at the end of this month hence the rush to get it fixed an prevent the indignity of having to make a SORN...
as a PS ... the headlight beam was a puzzle... what do they do when testing a car fitted with Lucas sealed beam units? IIRC these have a beam pattern rather similar to a fried egg don't they?
Fail points:
