since it is a '91 you can legaly remove the cat if you want. A straight pipe will give a different exhaust note, but you can put in a std box to keep the same sound. Otherwise a good exhaust place should be able to weld the flange back, or adapt it in some way so that a new cat is not necessary.
David
