I am having a lot of problems with the TCS system. I have changed the throttle body last week which seemed to have cured it. However it keeps throwing another fault code, code 22220 if I recall corectly. This should be related to a missing +30. However, if I put the contact in the on position, I can hear the relay thicking in the glove compartement while there is no movement in the car. Yesterday, I could even drive the car for over an hour without problems.
Can this be related to a dodgy ecu under to seat, or do I have to look for a bad connection somewhere? I already have cleaned all the connections with contact spray.
Any info is appreciated.
Edit: the car is a 92 9000 2.3T carlsson
