I have a current problem with my 95 Aero (85k miles).
The engine seems to feel rough/ vibrates, especially from 3k+ rpm. The 'edge' has also gone off the performance. Turbo boost still reads normally.
Occasionally, the fault clears (no particular circumstances, but I tend to notice when starting on a new journey)& the engine feels fine with improved power.
Any clues where to start looking?
Sounds as if it may be the DI starting to go. I had one that had these symptoms, it got gradually worse until it felt like it was only firing on three cylinders all the time. If you have access to a known good DI try swapping them.
Sounds ignition-ish then. I'll try new plugs & look out for DI. Is breaker part viable or go new? Daft question - is there 1 only or 1 per plug (I've not looked at the manual yet - can you tell?)
Ta
Steve
Given the issues that I have read regarding DI unit, I would suggest that it is a false economy to go for a breaker part. Buying the part new will give you a warranty should anything go wrong.
It's one unit that drives all four plugs. As for buying a used one, you can't be sure it's not already starting to fail. I have it on good authority that reliability has improved over the years, so a new one should last longer than the previous one did as long as there isn't another fault causing it to fail (wrong plug type, wrong gaps, etc.).
