I would appreciate any thoughts on renewing the bottom offside engine mount on my MY94 2.3 lpt auto. Haynes manual says I need to lift the engine with a hoist to remove the mount, but as I don't have access to such equipment does anybody know a 'codge' that might work?.
The best way I know of is to use a length of 2x4 or 4x4 placed on a hydrolic jack (prefferably) and positioned under the oil pan or sump. However if you are replacing the oil pan seal as I did a few weeks ago
I had to be quite creative to get the engine lifted enough to manuever the oil pan out and back in without destroying the sealant. Not an easy one person job. Engine mounts on the other hand are much easier. Hope this helps and best of luck.
