Engine coolant reservoir and bonnet struts.
I am seeking to remove the engine coolant reservoir so that I can clean the coolant level sensor mechanism. However, I cannot work out how the reservoir is attached to the engine bay. My Haynes Manual refers to a bolt but does not show an illustration. In comparison the steering pump reservoir just lifts out without any problem.
I have felt around under the reservoir for a bolt but can't find anything.
Another issue that I am wishing to find out about is the correct way to install the bonnet support struts. With the bonnet in the open position should the body of the strut be on top with the sliding shaft attached to to the guards?
Unfortunately Saabs are rare where I live and I can't look at someone else's car to check.
