1 - 1 of 1 Posts
I have non memory passenger elec seat adjuster on pssenger seat. It will not operate when the car is first used but after a few miles it works fine. The drivers seat adjuster works normally.
The seat switch has been replaced without solving the problem so I assume the problem is either in the feed to the switch or from the switch to the motor.
Can anyone tell me the route of the cables to the switch so I can check connections etc Fior example do they run from drivers seat to pasenger or are they independently wired back to ignition switch? And if so where do the wires run? Any other ideas/suggestions welcomed
1 - 1 of 1 Posts
