All the instructions I can find for replacing the mast say 'Remove the nut, turn the set on and pull the mast out'. Well I've nearly pulled the wing off, and it still didn't come out!!
Any ideas anyone??
Pete.
pete,
you need to access the screws which hold the unit on from inside ., Pull the carpet stuff away from the area where the ariel is ,working indide the boot. There are two screws I think and you'll need the hex head screw driver from the toolkit, You dont need to buy a new unit if it's just the arial itself , you can buy a saab replacement mast for £11 ish, tricky to fit but easy if you've done a couple like me.
