Hi guys,
Hope you all had a lovely Christmas. It was sunny and 30 degrees here in Brisbane, balmy and fine for x-mas day.
I have a question about the EDU display in my 86 turbo. The digital section ofthe display has all of a sudden faded, almost completely away, to thee point that it is only visible when the car is in the gaarge. The digital readout and the function(l/100km, etc) is the only section affected. The check engine warnings are all still illuminated fully. Is there an easy fix? It assume it is LED display and not bulb illuminated.
I did a search but never found anything resembling this problem.
Other than that, after 2 months I am happy with the car. New oil and filter, plugs air filter, coolant, and brake fluid all replaced; just leaving gear-box oil and power steer fluid still to do. Only have to work out what has been by-passed for a relay in the a/c circut and repair it.
It pains me to say this(being a French Car Fan from day dot....Saabs are very well made and most probably the most logically assembled car I have owned. After 1 Holden
3 Peugeots, 1 Fiat, & 7 Renaults)
Cheers from Australia.
Chris
Chris
