On the way home last night, I noticed the battery light glowing dimly on the display. If I increased engine revs, it got worse. Down to idle, it went away. So I drove for a while with as lower revs as possible. I had a brief burst of high revs to overtake, and it went away. Tne it came back again.
Looked at it this morning, and took the following readings with a DMM:
Idle: 14.0V
Idle & lights on: 13.1V
1500rpm: 14.1
2000rpm: 14.2
2000rpm& lights on: 14V
The after it had been running a while I went back and checked the idle voltage and it was 12.9V
There's also a whine coming from the alternator area that increases when any signifcant load is turned on. Across the terminals of the battery there's about 0.4V p-p sawtooth.
Brushes, bushes, regulator or all 3?
Idle: 14.0V
1500rpm: 14.1
2000rpm: 14.2
