Been reading around a little on dump valves and was wondering if ther was a way to check if the original Bosch item on my car was working properly.
Currently experiencing some "underpower", possibly due to a need for new air filter and is due a oil & filter change and general check on plugs, etc.
Also, when doing the exhaust mainfold gasket I noticed a small amount of partly dried oil in the bottom of the intake side of the turbo. Should this be a big worry? car is 2.0 LPT with only 56k miles on clock & FSH.
If any other common causes of a general (not sudden) lack of power above 3krpm, then I would be glad of a few pointers on what to look for (e.g should I get a pressure gauge on inlet manifold to check boost, etc).
TIA,
Pete
TIA,
Pete
