Hi All,
I own a 2008 9-3 2.0T, and my friend owns a 2007 9-3 2.0T sport combi (anniversary edition). Is there any drastic change to the power steering between the two models? The 2008 has lighter steering and not nearly as much feeling when you hit a corner, compared to the 2007 which gives you much better feeling and feels more solid all around. Not as jittery on the road.
Both are running more or less comparable tires... the 2008 has V12 Evo's and the 2007 has AS potenzas. If anything id expect the evo's to feel better through the corners.
Before I go searching the 2008 for tie rod and suspension issues, likely messing up the alignment in the process and costing myself $100 to fix it, is this change in feel on the road just an inherit difference between the two? The lack of feel bugs me a bit on the track.
Thanks!
Thanks!
