1 - 9 of 9 Posts
Hi,
as some of you might know, I´m planning on upgrading my Viggen Convertible´s suspension. So far, I want to get the Abbott Viggen Rescue Kit and Abbott Springs. Later, I want to add Koni Dampers. But do I still need an uprated rear anti roll bar? I read somewhere that the original Viggen anti roll bar is already nearly as stiff as the Abbott anti roll bar?!
Thanks,
Philip
Dunno if you need the uprated anti roll bar or not but according to EPC, the rear roll bar is the same on all 9-3s, including the Viggen. There are however 3 different front bars and I know the Sport has a different one to standard, presumably the same as the later Aero. The third might be Viggen specific or might just refer to non-turbo variants (all EPC refers to is Code A, B or C)
I had the same dilemma a few months ago. The rear anti-roll bar is the same on the Viggen as on the rest of the range and isn't really upto the job of keeping the car stable when
I had the bar fitted to mine along with the VRK and it's made a big difference. I used to find the car pitched about a bit when cornering, but that's now been cured and it feels much better balanced.
Thanks for the many quick responses!
@sentinel: But you didn´t try the VRK WITHOUT the upgraded anti roll bar, didn´t you?
Yours,
Philip
Originally posted by philip hs:
[qb]@sentinel: But you didn´t try the VRK WITHOUT the upgraded anti roll bar, didn´t you?
[/qb][/b]
I did actually . Originally I had only booked the car in for the VRK.
I had a chat with Ed and Giles about further improvements while that was being done and the roll bar came up as one of the suggestions. Had a test drive with the VRK only and then decided to have it installed - I was very impressed with how quick they managed to make one as they didn't have any in stock.
Thanks, Sentinel,
I think I will go your way. What did you have to pay for VRK + Anti Roll Bar + Fitting + VAT?
Yours,
Philip
Had a search around for the invoice and heres the breakdown...
Viggen Rescue Kit £495.00
Labour on fitting £85.00 (fixed price for 2 hours)
Rear Anti-Roll Bar £145.00
Labour on fitting £15.00
VAT @ 17.5% £129.52
The total's a bit too depressing to type , but the car is totally transformed.
I'm still not 100% happy with the standard springs and dampers, but this is only really a problem when you have a bad road surface and throw in lots of camber changes when you're travelling at (very) illegal speeds, so I'm not exactly in a rush to replace them just yet.
1 - 9 of 9 Posts
