Ever since I've had the aero I've noticed that the revs don't drop too quickly when changing gear. I was under the impression this was perfectly normal but lately after every gear change the revs stay quite high. Also I've noticed that the car seems to pull itself forward even when I've let go of the accelerator.
More frequently now when coming to a stop the revs will rise and fall and this has also happended on a few ocassions when I've started the car up.
We used to have this problem with our old 9000 CDE
and it seemed the lamda sensor was the problem. Although having changed this a few times we still had the same problem. My first thoughts were is it the same problem? Or could it be a dodgy IAC valve that perhaps needs cleaning? If so what sould I use to clean it?
Zahid
Zahid
