just recently my car is not always boosting beyond half way into the orange, however when i take the w pipe off the apc solenoid its fine, does this mean my wastegate actuator is faulty? and if i leave this hose disconeected will my apc system be bypassed leaving my car vulnerable or will my over boost cut off still work. i really miss my
but dont want to put strain on my car thanks in anticipation
I'd refit it and investigate the problem. You now know that the turbo will boost to the red/cutoff.
I would never run any on my cars with the wastegate disconnected (wedged shut...).
The thing to check is is the boost is the same or lower with the APC solenoid plug disconnected.
If it is lower disconnected then the APC is working and reducing your boost,
If it is the same then you have an APC problem to track down.
Andrew.
