Help! Just swopped my 9000CSE for a 2000 9-3SE. Been trawling through the owners manual (as you do), and have found the bit about the Glass Break Sensor. As I wish to sometimes leave the dog in the car, wth the windows slightly open, I want to try setting the alarm to "Door Alarm Only". I have tried holding down the Night Panel, with no key in the ignition, but nothing comes up on the SID. All advice greatfully received.
IIRC this is the procedure:
1. turn off engine. do not remove ignition key.
2. hold down NIGHT PANEL button until a message is shown advising deactivation of that part of the alarm
3. remove key from ignition.
4. lock car within 2 minutes.
Now, that lot is from memory and it could be wrong. I shall try and look up the procedure to clarify it ...unless someone can beat me to it.
Help! Just swopped my 9000CSE for a 2000 9-3SE. Been trawling through the owners manual (as you do), and have found the bit about the Glass Break Sensor. As I wish to sometimes leave the dog in the car, wth the windows slightly open, I want to try setting the alarm to "Door Alarm Only". I have tried holding down the Night Panel, with no key in the ignition, but nothing comes up on the SID. All advice greatfully received.[/b]
This must be done within a specific time after the engine is turned off. Ingition key must be removed before pushing the Night Panel button.
Are you sure that there's alarm system in your car?
