Hi All
Just trying to find out the difference (Besides the turbo) between the aero engine and the engine in a 91 2.3T? I know straight away there is 25hp difference but does the aero engine have larger injectors,fuel pump, fuel pressure regulator ect?
Dan,
Spirit,
in 1991 I think the Compression Ratio was 8.5, in 1993 on mthe Aero it was 9.2
Aero's hve Mitsu TD04-Hl Turbo's, the others have Garretts
In 1991 it was DI/APC and Bosch injection
In 1993 Aero's had Trionic.
in 1993 the injectors have a double spray (1 for each inlet valve, not sure if this occured in 1991
That's a start, others will add more I'm sure.
Don't forget that most Aeros will be 1994-
1994- Aero engines are the same as all other 1994- 2.3 turbo engines. However, these in turn are different from -1993 2.3 engines. In particular the heads and blocks are different. The block from a 1994-, for example, will only mate up with a 1994- gearbox.
Alanb
