Following the above through to some sort of illogical conclusion, is then possible to "upgrade" a simple 96 2.0LPT B204L by replacing the ECU from higher spec (performance wise) model? Sounds too easy, so probably isn't.
Cheers,
Pete
Pete,
No, not with an OEM ECU as there was no "higher spec" version of the B204 fitted to 9000s- it was LPT only.
However there's plenty of aftermarket tuners who will do the job for you...
