I found this on a cached page on the internet - I was unable to determine the source of the information or whether it is online at another domain?
/john
Using Check Engine Lamp
(1988-92 LH 2*4, 2.4.1 & 2.4.2)
Read the following procedure carefully before turning ignition on.
On 900 models, use a switched jumper lead No. 8393886, or equivalent, to ground No. 3 pin in the three-pin test connector located on the right side of engine compartment.
On 9000 models, use a switched jumper lead to ground the single pin socket on the test box located on the left side of engine compartment.
On all models, turn ignition on. The check engine will illuminate. Turn the jumper lead switch on (grounding ECU pin 16). The check engine light will now go out. Watch the check engine light carefully. After approximately 2.5 seconds, the check engine light will flash briefly, signifying that the first diagnostic trouble code will be displayed. Immediately turn the jumper lead switch off as soon as the check engine light has flashed. The first error DTC's will now be displayed by a series of short flashes of the check engine light. The error DTC starts and ends with a long flash of the light. These long flashes are not part of the DTC, but indicate the beginning and end of the DTC.
If the test is run with the engine off, DTC 12231 (no RPM signal) will be the first DTC displayed. As soon as this DTC is displayed, turn the ignition key to the Start position and hold it there until the ECU acknowledges by flashing the check engine light. The signal is being generated. At this point, let the ignition key return to the Run position so the next DTC can be displayed. With the jumper lead switch set to off, the same DTC will flash repeatedly. Any additional DTC's cannot be displayed until the jumper lead switch has been operated as follows: Turn the jumper lead switch on. After a short flash of the check engine light, turn the jumper lead switch off. The next DTC (if any) will then be displayed.
Repeat this procedure to display a third stored DTC, if any. If a third fault has not been detected, or all faults have been corrected, the system will indicate this by a continuous series of long flashes of the check engine light, or by displaying DTC 12444. 9. To display the DTC's again, starting from the first DTC, proceed as follows: Turn the jumper lead switch on. After two short flashes of the check engine light, immediately turn the jumper lead switch off. The DTC for the first fault will now be displayed.
Using LH System Tester
(1985-92 2.2 LH & 1988-92 2.4 LH)
Prior to connecting tester, clean battery terminals to ensure that the power supply lead clips make a satisfactory contact. Always connect power supply lead to the tester first and battery last. 1. Remove cover on left hand side over space behind false bulkhead panel. 2. On models equipped with anti-lock brake system (ABS), remove ABS ECU and bracket. 3. On all models, connect test lead between vehicle ECU and wiring harness. Use a couple of suitable ties to hold ECU and test connector together. Connect power supply lead to tester and to prevent it from being pinched, run it between door and body where there is a break in the seal. Connect tester leads to battery, negative terminal first, then the positive terminal. Select "TEST MODE" feature on LH system tester and read any diagnostic trouble codes stored in ECU memory.
Using ISAT System Tester
(1990-93 LH 2.4 & 2.4.3,1993-95 MOTRIONIG ENGINE MANAGEMENT SYSTEM, 1994-95 MOTRONIG2.8.1 & 2.10-2, DI/APC & EZK IGNITION SYSTEMS)
Connect SAAB ISAT tester, or equivalent, to the diagnostic connector located under the right hand rear seat on 900 models, or under right hand front seat on 9000 models, per manufacturers' instructions. Never unplug connector from ECU or disconnect either of the battery leads before faults have been transferred to tester.
Clearing Diagnostic Trouble Codes
To clear DTC's from check engine lamp, proceed as follows:
Turn the jumper lead switch on. After three short flashes of the check engine light, turn the jumper lead switch off.
The check engine light will now either flash in a continuous series of long flashes or display DTC 12444, indicating that the contents of the system's memory has been erased. After diagnostic trouble codes have been transferred from ECU memory to the LH system tester, DTC's will be cleared from ECU memory.
To clear DTC's when using SAAB ISAT tester, or equivalent, follow tool manufacturer's instructions.
Diagnostic Trouble Code Identification
Fuel Injection & Engine Management
Using LH System Tester (1985-93 2.3 LH)
DTC Circuit Or Condition
E001 No Ignition Pulse
E002 No Signal From Engine Coolant Temperature Sensor
E003 Throttle Position Sensor (Idling Contacts Do Not Close)
E005 ECM Pin 5 Not Grounding
E006 Mass Air Flow Sensor Not Grounding
E007 Mass Air Flow Sensor, No Signal
E008 Mass Air Flow Sensor, No Filament Bum-Off Function
E009 Main Relay, No Power Supply
E010 IAC, No Signal From ECM Pin 10
E011 ECM Pin 11 Not Grounding
E012 Throttle Position Sensor (WOT Contact Not Closing)
E013 No Injector Pulses
E014 Mass Air Flow Sensor, Break In CO Adjusting Circuit
E017 Fuel Pump Relay Circuit
E018 No Power At +15 Supply Terminal
E020 Faulty Signal From Heated Oxygen Sensor
E021 Main Relay Control Circuit Faulty
E023 No Signal From IAC Valve
E024 No Load Signal
E025 ECM Pin 25 Not Grounding
E101 Starter Motor Revs Too Low
E102 Short In Engine Coolant Temperature Sensor Circuit
E103 Throttle Position Sensor (Idling Contacts Do Not Open)
E107 Mass Air Flow Sensor, Signal Too Low
E108 Mass Air Flow Sensor Filament Bum-Off Function On Constantly
E109 Main Relay, Power Supply Too Low
Very interesting John. The method of checking the fault by counting the flashes of the "Check Engine" light is well documented on the Townsend Imports site at; http://216.78.173.190/engine_folder/24codes.htm. but is only applicable to 9000s prior to '93. There after you need an ISAT connected to the connector under the seat. The rest of the article might be useful in the unlikely event that I ever lay my hands on an ISAT
