My CSE's engine (1995 2.0LPT) is making quite a bit of noise. This follows an oil leak complicated by a non-functioning oil-level sensor and, worst of all, oil pressure sensor. The oil was very low and refilling has not got rid of all the noise.
I think some of the noise is at the big ends but there does seem to be a loud knocking from the cam cover so I've removed that and the camshafts for inspection.
There is barely-visible scoring on the cam bearing caps and none on the camshaft bearing surfaces. Also no visible wear on the cam followers and the cam lobes. The grooved bolts on the bearing caps, designed to carry oil to the followers, are clean and clear.
So, assuming the noise was coming from the valvetrain, what could it be? A faulty follower? If so, how can I tell which one? With the camshafts off, none of the followers is sitting noticeably lower than the others.
If I leave the car idling, the noise will lessen briefly, then return. No amount of running or idling will make it go away.
I want to cure any top-end noise (or eliminate the top-end as a possible source of the noise) before going to the bottom end. The good news, though, is that my specialist tells me there's a good chance that even if the big-end bearings need renewing, the crankshaft will be OK so I'm hopeful that it won't be an engine-out repair.
