Hows this for an Idea (PAT PENDING)
On the 9000 the front ar bar is coupled to the wishbone with a drop link
Idea
substitute one of the drop links with a suitale length and bore double acting pneumatic cylinder
control the ports with poppet valves and restrictors and you could ....
decouple it for max traction
in yaw shut both valves for max anti roll effect
on the straight ahead somewhere between the two
All you would need is a couple of accelorometers and a simple control circuit and roberts your mothers brother
even more simple is just have a poppet valve so you can switch it on and off (poverty spec )
If I can find one the right size might even try it @ anglesey...
Idea
