A week sitting at Gatwick was enough to completely flatten the battery - 60Ah or not. It was at least two years old, so I had no problem replacing it (apart from paying, of course) but there was a curious symptom driving back once I got it jump started.
It didn't want to idle at all - with minimal electrical loads on the system - even after three hours of driving. Is it a; the adaptive engine management not adapting; b; the large load caused by a flat and probably knackered battery; c; something more sinister?
Also curious was the open circuit voltage on the knackered battery when I took it out - 12.8V - theoretically about 90% charge. But at that state it only just started the beast to get it around to my garage for the battery swap.
Finally - I know the handbook says any volt display below 10V on starting means the battery is not too healthy - but even with the new shiny trickle charged Varta in, the instantaneous volt display on starting varies between 11V and 8V. Running volts are nice and normal at 13.9 - 14.4 V
