Same as non airbag models! Release door seals by A posts, pull off A post trims, remove speaker grilles (3 screws) and rubber baffles (if still there), carefully discon alarm LED (if fitted),This will reveal obvious fixing screws. From top right of pass. airbag unit remove the soft 'SRS' badge (get you finger nail behind and it will pull off), thus revealing a fixing screw. Another fixing screw is located above instrument window, you will feel a little access hole in line with '3' on the tachometer. If car has climate, discon the sunlight sensor on dash top panel. Top panel removed!
