hi all,
have a problem on the new carlsson, when the lights are on there are no lights on the total dash, not just the display,
does anyone know where to start or what fuse to look at because when it comes to electrics im baffled
thanks
mark
Apologies if this is too obvious but have you tried the Dimmer Switch ?
Also the Fuse box has a fuse marked "Instruments" ??
If the Dimmer switch is positioned correctly then check for a feed to it, could be a faulty switch.
Cheers C
