The brakes on my wifes 94 CSE are'nt as good as they should be. The brakes work 'eventually' but there is very little initial bite. Being an automatic the problem seems worse at slow speed (sub 10 mph) and not as noticeable above 25 mph.
The pads, discs, brake lines all seem OK and I can't see any signs of leaking fluid from say a cracked caliper.
I took it to the local garage who are honest & cheap, the brakes all register the correct stopping force on the MOT tester and they sat the pistons slide Ok within the calipers. they could'nt figure out what was wrong with them.
I noticed that there does'nt seem to be a brake servo.
The local garage chap said his technical book mentioed a SAAB diagnostic brake checker, but only on later versions, however he has'nt got one and was'nt sure how to connect it if he had.
Any thoughts on what the problem might be ?
