Firstly, my 9000 has ETS, so there are no vacuum lines to leak. Also I have checked out the Brake and Clutch switches and they work fine.
SYMPTOM
When I'm doing abour 30mph, pressing Set has the desired effect and Cruise works fine. If I then hold in Set to speed up the car, the Cruise drops out at about 35mph.
If I try to Set the Cruise at any speed above 35mph it just refuses to work.
Any ideas?
(If anyone can post a schematic of the Cruise and ETS connections for a '93 I would be very happy)
Regards,
Antony.
Antony,
I do not have any real idea but I would check:
That there are no check engine light flashes if you switch the ignition on but don't start the car (5 flashes = throttle position sensor = cruise problems).
That the pedal switches are set correctly and not 'chattering' as if either the clutch or brakes were touched.
