1 - 8 of 8 Posts
Thanks all,
I think I'll leave this one to the garage, don't fancy crawling around in the footwell upside down
Had to replace one of the vac' pies from the dump valve as it had split. Need to do the other two. How easy/hard is it to do the one that goes through the bulkhead? Help is appreciated.
Keith.
I think it's pretty easy, as the pipe shoul be one ppiece just from the engine bay to the bulkhead, where a joint omnted on the bulkhead joits it to the other piece. The CC vac hose has it, I'm pretty sure the other pipe (boost) has it too.
If I'm wrong and it's a unique piece straight through the BH, it should be easy simply removing the dash top, ot the kickpanel, or both. Seeing the attitude you've shown in your above post, if there's no joint my advice would be "take it to to a garage, or let sombody do it for you". . It's very cramped in the dash.
1 - 8 of 8 Posts
