1 - 18 of 18 Posts
Is there any reason why my cruise control would not be working after software update? It was working ok before, I called them back and the technician is saying software update should not affect cruise at all. Is it possible that it got reset to OFF by default and now needs to be enabled by Tech2?
Best guess would be the brake or clutch switch has been dislodged by tech 1 plugging the Tech 2 into the OBD port which is just above the pedals.
Cluth would make sense, as no brake activity gives "Tap brakes lightly before engaing CC" on the SID.... (or something like that)
Update: been diagnosed a faulty cruise control stalk switch.
Is it enough to replace just cruise/turn signal stalk? No need to replace whole CIM I hope?
Yeah, you can just do a straight stalk swap. I've done exactly this in the past (not because it was faulty, but the white markings had worn off. Replaced it cos it bugged me... Got it off ebay for around £20 if I remember).
Turns out it's not the stalk that's making cruise control not to work. I've swapped the stalks over with another 9-3, and it still didn't work, my stalk worked fine on the other 9-3. So where should I look next? How do I get to and remove clutch switch?
Discussion Starter · #13 ·
so it might be CIM you say? but I have no other issues, apart from maybe SID intermittently telling me about front fog bulb failure although it's fine.
Cruise control used to work ok, although it was cutting off sometimes, then I had the software update at official Saab garage using the £9.99 deal and it won't work at all since then, light on dash is on but won't set speed.
Ok, so let's establish what components could affect cruise function: there are the clutch and brake switches and the stalk with it's buttons, which then connects to CIM and that goes straight to ECU? Do the clutch and brake switches connect directly to CIM, ECU or something else?
Premium Member
alot of things indirectly related to can affect cc..........what car do youhave year etc, pm me your email will try to send some info tomorrow
Discussion Starter · #15 ·
Had given up on my cruise control over winter but now would like to try and make it work as summer is round the corner and more motorway miles are bound to be covered.
So the clutch switch was fine although I replaced it anyway as I broke its clips when taking out. Noticed there are 2 switches on the brake pedal, is that just a backup in case one failed or do they control different things? My brake lights are working fine.
Premium Member
your brake switch will disable cc
just odd that only happened when you had software updated...........as though its been switched off as would expect sid to display a fault otherwise
Discussion Starter · #17 · (Edited)
I know it will disable, but maybe if there's an issue with brake switch it won't let cc to come on. Actually before software update my cc would cut off occasionally but after the update it didn't work at all. Is it possible to deactivate cc by tech2?
Discussion Starter · #18 ·
I did a bit more investigation with OP-COM:
Text Blue Font Line Screenshot
The 3 marked values remain INACTIVE as I drive and try to engage cc. Now as I have another 1.9TID SS handy, I tried same thing on it and as I hit 20mph the "Vehicle speed in cc range" turns ACTIVE, and when engaged the "Cruise Control" value turns ACTIVE, if I switch cc button on stalk to off, the "Cruise control tip switch" value turns to "O(off)" whereas on the faulty cc car all values remain inactive no matter what I try. I have swapped the stalks around, so I know they are both good. Any ideas where this is pointing to?
1 - 18 of 18 Posts
