CRANK SHAFT GONE
1904 Views 3 Replies 4 Participants Last post by  California Saab Tuner
WHAT DO THE GUYS THINK OF THIS?
fOLLOWING A VERY EXPENSIVE ENGINE REBUILD INCLUDING NEW PISTONS AIRFLOW HEAD(ABBOTT) TURBO(GARRETT) INTERCOOLER AND ALL CHAINS TENSIONERS ETC ON MY 1992 9000 CS CARLSSON I'VE LOST THE CRANK SHAFT WITH A HORRIBLE GROAN IN ONLY 1000 MILES OF LIGHT RUNNING IN.
MIGHT i HAVE EXPECTED THIS?
SICK AS A DOG
Certainly not, but has your oil pressure light been working? Has the oil level been up to the mark? Surely the oil pressure can't have been there for such a thing to happen?
In any case terrible luck....
Nick.
That's sickening.
I would say that something possibly with the rebuild went wrong.
You say you had new pistons, so the bottom ends been out. How was it put back?
If you rebuilt the engine yourself you might just be out of luck. I've built a few motors and it's a meticulous process even if you've done it many times before. Sometimes things like crank and rod bearings are out of spec, and any number of small things can go wrong. But ... if someone ELSE rebuilt it ... Give em a swift kick in the bum and make em do it again!! lol
If you're rebuilding it yourself, and you have to again. Get some "plastiguage" and test fit all your main bearings and rod bearings. This saved us easily $2,000 on our Formula Ford when we got a set of bearings that were out of spec. Would have easily chewed up a VERY expensive crankshaft. You put the gauge in the bearings and tighten them to spec, then remove it and measure the thickness. It will correspond to a specific oil clearance that should be listed in a good repair manual. This is one of those crucial steps that 90% of the professional shops out there neglect to do. They can afford the 10% out of spec rate by just rebuilding 10% of their motors twice, then 10% of those three times etc. It may only cost $2 per engine or so to do the plastiguage, but it's labor and time intesive so it's then not cost effective. If anyone rebuilds their own motor, don't risk it. Just buy the stuff! Anyway ... sorry about the bad luck dude. That sucks!!
See less See more
