While examining my dads Aero to find out why his turbo wasn't working (operating rod disconnected) I noticed he has a crack across the exhaust manifold just above the turbo flange, part of which is blowing exhaust gases.
Is this a common problem, & what is the suggested fix
a, In situ welding (cast iron ?)
b, chemical / liquid metal
c, remove & replace manifold
d, something else ?
The car only gets 3000 miles p.a use now, a bit less than the 50k it used to in my hands
I know what you mean about the manifold studs Ylee, I just looked at the manifold / turbo assembly and though "I really don't want to get involved in that lot"......envisioning hours or days with penetrating oil, stud extractors, grinding wheels etc. I bet you had the engine out when you did yours too
We might know someone who can weld cast iron in situ. If not I think we'll give the chemical metal a go, after all it's only £5 wasted if it doesn't work.
I got some-one else to do it !!!
Do not even waste your money on chemical metal
all you will succeed is making a horrible smell as it burns away !!It does not have the heat resistance required for an exhaust manifold.
I would try the welding as a stop gap
Altho mine was severely cracked I never noticed and must have had minimal leakage
I would guess that as long as the crack is not spreading you might be ok (but have a second hand one ready to go if it goes !!)
good luck !
