Hello. My car has recently developed a kind of misfire/starting problem. When starting cold the rpm rises up to 1500 and then drops. It keeps on falling right past it's normal idle point and stumbles around at 250-500. From there it either cuts off or goes back to 1500 to try the whole thing again. This goes on for maybe 30 seconds, then idles around 800-900. Also sounds a lot rougher at idle and when driving at low rpm.
I talked to someone on the phone from a parts supplier (forgot the name). They said it sounded exactly like the coolant temperature sensor. The symptoms showed up right after I reset the ECU and cleaned the air temp sensor. The air temperature sensor appeared to have a scorch mark on one side, but he said it couldn't be causing my problem. As from my previous posts, I've been having some trouble with misfiring under load, and have concluded that it has to be the fuel pump. (only thing I havn't replaced!
Could this just be the fuel pump getting worse?
