Hello all. '93 9K CDE, non-turbo, auto.
The next repair I'm planning is to replace the control arm front bushing supports. I'm getting a clicking sound when going over small bumps at low speed. I checked them out, and 3 of the 4 are broken.
I've got the service manual and it looks relatively easy: remove the 3 bolts on the ball joint, unbolt the sway bar link, then remove the bolts holding the support. Refitting, as they say, is the reverse of removal.
Then again, everything looks relatively easy when it's written in the book...
At the same time, I'm planning on doing the sway bar drop links and bushings, as well as the sway bar bushings.
Anything else I should know? Caveats, things to watch out for?
Thanks,
mike
Thanks,
mike
