The rear front ones?
1 jack to raise the car,
1 14mm Socket for 2 bolts
1 13mm socket for the other 2 bolts?
1 18mm open ended spanner for the bush bolt.
Elapsed side change duration, about 10min including jacking.
The only catch is that you're not supposed to tighten the 18mm bushing nut until the car's back on the ground.
I had to find a short 18mm wrench (sorry, spanner) to tighten the nut when the car was on the ground. Not much clearance there...
mike
