1989 9000 2.0 non-turbo 150,000 miles
Starts after a fair bit of turning, but will die after 10 seconds. Attempts to rev the engine cause spluttering and coughing.
Hard-wiring the pump I can get fuel flowing freely through the injector rail to the pressure regulator's input, but when I reconnect that, nothing comes out the other side of the regulator. So, my pump is not producing sufficient pressure to flow through the regulator.
This suggests that the fuel pump is weak and that it is not producing sufficient pressure to run the engine. Or will a siezed-shut regulator (causing over-pressure) display the same symptoms ?
More diagnostics....
Was given various second-hand 'useful spares' with the car.
Tried 2 other ECUs - no difference.
Tried another airflow sensor - no difference.
Unplugging the idle control valve - no difference.
Checked the throttle position switch - all works as it should.
Sparks are strong and continue to spark while engine is misfiring.
I've looked on various BBs and forums which suggest possible causes, but........
There is no DI cassette thingy on my car, so it ain't that.
All hoses and electrical connections are clean and in good condition. No vacuum hoses are split/holed.
It isn't a blocked filter, because fuel flows freely as far as the in connection to the pressure regulator.
The car has run well enough in the 2 months I've had it - this problem came on without warning over a few miles last night while cruising at 60. It has done it twice before, but both times it started again and ran perfectly after a 10 minute rest by the side of the road. This time, it seems permanent.
Mike
Mike
