Want to fit a second hand driveshaft and Hub the the missus's 93'K' 2.3T Grffin before the trip to danepakland. What other saab's share this part before I go out and get myself the wrong bleedin' one!
For 93 model year I think the driveshafts for the 2.3T were not fitted to any other model than the 2.3T. The manual has different part numbers depending on left or right where as the auto only has one part number (same as manual right hand) however this same part number 4105235 also used from 94 -98 in the 204L, 234L, 234R & 234E auto (same part for both sides)
Hope this helps
It is an auto (as all Griffin's were) so klets get this straight, the part no. I need is also the same as on the other saab's you listed. That will make my life a lot easier!
Yep that part number shown as fitted to 94 - 98 model year engines as indicated (basically turbo ones). BUT I'm just passing on info I've seen listed elsewhere so worth ringing you local dealer to confirm.
